AB PLC 1769-L35E/A direct printing
matejmm
Mar 2011
Ljo
Hi, i would like to generate report an print it from PLC. I heard thet raw ASCII printing can be done direct from PLC. I'm using Allen Bradley 1769-L35E/A PLC. Does anyobody knows any functions or commands for plc printing. I know how to print reports from Panelview(1000 compact) terminal(i can help with that if anybody needs advice). I saw an option in contrologix5000 SW :File-> Generate Report, but im not shure if this is it.
Anyway i would be really greatfull for answers, because i read alot of manuals and nothing.
Berni, I thought so. Maybe if PLC could communicate with printer trough RS232-LPT or RS232-USB converter, but i dont know which function/command to use.
it's been many years since I've done this - so take everything I say with a grain of salt ...
since most printers these days are PARALLEL devices - you'll probably need a serial-to-parallel converter between the CompactLogix SERIAL port and the printer ...
the commands that you'll need will be ASCII instructions ...
basically you format/build a STRING - and then use something like an AWT command to send the string out from the serial port ...
and under the Controller Properties feature, you'll need to configure the CompactLogix serial port for User mode ...
I helped a customer set up a system which would print out paper copies of "alarms" and such - so I know that this can be done ... we used a PLC-5 for that application ... I assume (gosh I hate that word) that the CompactLogix will be able to do the same thing ...
hope this helps to get you started ...
while i am trying to change ip address online , plc has gone to conflict mode. Now i want to restore the factory settings for allen bradley...
17,989
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
460
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
453
looking for the the MAC address for this PLC, I count find it in the front or at any part of the PLC itself. connected to the PLC by USB, showing...
1,811
hello plc professionals , i have a plc AB 1769-l24er and 13 VFD AB 525 and HMI and STRAIX 2000 unmanaged switch .. the LOGIX Designer limiting me...
1,570
