AB PLC 5/11 Lost Program
RWC767
Sep 2017
Houston
We have a AB PLC 5 system with a 1771-OVN module has no indications lit although the other IO modules have indicators lit. During hurricane Harvey the system was powered down for several days. When power returned the system did not return to operation. We checked the battery and it was less than 2 vdc. Proc light is on RED and the green A light flashes on and off. From what i have read it seems the program is gone. Any opinions or suggestions on how tell if the program is still there? This system is of course old and we do not have the programming software.
Call your local AB rep. You will have to go online to see if the program is there.
You need the programming software to do this.
Hopefully you have a back-up of the program somewhere.
The PLC-5/11 has a memory module slot on the front of the controller, between the status LEDS and the battery cover. If there is a memory module installed, it's possible that the program is stored there and it just requires a technician to go online and command the transfer from EEPROM to RAM.
If the memory module is not installed, then the program is definitely lost from the controller and it will need to be reinstalled from an archive.
This is bread and butter work for most automation system integrators. If you don't have one you use regularly, call your local A-B distributor (for Houston, it's Reynolds Company) and ask for their recommendation.
Hello, I have an old Micro Logix PLC program which has no tags. When I go online with this program, the tags are not there either. Is there any...
6,298
Have a redundant pair of PLC 5/11's on a roller coaster. Everything is going fine, then the coaster went into e-stop. I went there the next...
1,581
I have a really old machine that was donated to my company. The PLC is one of the oldest ones I have ever seen. It is a "mini"<-yeah right, 2/15...
3,393
Whenever I turned off the power and on back for S7-300 DP315, I will have to re-download the PLC hadrware and OB1 to get the program run. Which...
24
23,608
Hi guys, This my first time posting hope I get help in my issue.. I have Allen bradley control logix safety PLC (1756-L61S) connected with...
2,317
