AB PLC AOI Local Tag Accessibility
Nan
Jul 2015
louisville
126
Good evening all,
I have a question regarding AB AOI and wonder if anyone can help me.
I am in a production environment so I can not change the AOI and apply. But is there a way that I can access the local tag without changing anything on the OI? The local tag data type is string [16].
Thank you!
No.
If the Local Tag external access is set to Read or Read/Write, then a HMI or SCADA system can access it. But the PLC logic cannot access AOI local parameters
You can have the controller send a CIP data table read message to itself. As ASF said, the local tag needs to be Read or Read/Write to be accessible, as well as the AOI instance. This gets PLC logic access.
If you are looking to change their values by hand in Studio, you can monitor local tags and change the context to the AOI instance.
Maybe, kinda, sorta.
What you can do is, outside of the AOI, COP the AOI tag to a DINT array tag with the same byte length as your AOI. Look at the AOI data type to get that value.
There will be some place in the DINT array where the string you are interested in will start. If you are using Radix to find the text of the string in the DINT array, keep in mind that the .LEN field is first, so if the AOI has string "HELLO WORLD", and you see "HE" in DINT[48] and "LL" in DINT[49], then your string starts at DINT[47].
COP DINT[47] to another tag that's the same data type as the one in the AOI (e.g., "String_16" or whatever its called), and that new tag will have your target string.
Here is my recent experience using the Zebra AOI for printing from the PLC. Please do not ask me for my PLC or template files as they are the...
12,410
Hi sir. We are using Control logix redundant PLC system which supports only PTP time synchronization protocol but from DCS side we are receiving...
2,448
Hi , I need to interface sensors "proximity", GPS, accelero meter, with AB 1400 1766 PLC .Currently I have RSLogix micro starter programming tool...
3,282
Does anyone know whether a Micro800 series PLC is COS or typical scan solve set housekeep (SSSH)
Hi there , when I trying to do some communication things with PLC , I think I made a mistake and now PLC has fatal error. Only error light turn on...
26
