AB Relay Output Issue
Saw no faults on the Device Net scanner or PLC fault tables.
MOD/NET and I/O Status both solid green when logically on and logically off.
Rockwell support thinks it could be a corrupt file, so export to LK5 and bring back, also rebuild chassis.
System goes back online later today so my trouble shooting could be done for awhile.
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
120
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,593
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,847
Troubleshooting a Eaton Easy719-AC-RCX. Have three digital inputs and one relay output. PLC input power 120VAC. Each digital input has a 120VAC...
2,018
Hi all, A client is asking if I can move a motion sensor from an existing alarm dialer to a PLC discrete input. Looking up the datasheet, it...
2,313
