AB SafetyLogix PLC - Losing Program
Redland Brick
Mar 2005
24
I would like to know if any of you have had a problem with going
online with a Allen Bradley SafetyLogix PLC. Sometimes when we
go online with this controller,out of the blue the CPU will fault
out , and we lose the program. I upgraded to the recent version of
RS Linx,it seems better ,but we still get bit by this problem from
time to time. I was in a hurry last time to get it up running,that
I forgot to get the fault code. Has you can imagine ,this causes a
lot of problems. I would appreiate your help. Thanks in advance.
48
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
73
281
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
198
