AB servo via Dnet
Steve Kemp
Nov 2003
122
Good day all.
Whilst not new to servos and with one (discrete i/o) Dnet application under my belt, I am now faced with the challenge of establishing communications between an SLC500 and an AB 3000i servo drive via a Dnet scanner. I've previously used GE-Fanuc (9030) plc/servo combinations, sending position, speed and homing data via move commands, etc. Is the AB approach similar? I understand "M" files are required as an intermediary, but the rslogix help library seems less than helpful. The application requires many positions and adjustments, so I'm not able to pre-program set moves into the drive. Any pointers or traps to avoid would be appreciated.
Thanks,
Steve.
Dear Friends, We have a setting machine in which 20 Parker Servo Drives and motors (name plate images attached) used to place the tools at...
3,880
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
76
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
106
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
99
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
71
