averytc
- Join Date
- Jul 2002
- Posts
- 114
Ok, I’ve run into something I’ve not seen before. It would seem strait forward, but. I’m comparing two integers N13:10 & N13:11 using the EQU instruction. When they are the same value, the rung should be true and a timer starts. I want the timer to reset when they are not true. This is the way it’s supposed to work, right?? I’m looking at the timer active with the enable bit and done bits set.
I've never seen this before. Am I missing something?
Thanks,
Charlie
Edit, I removed the drawing. How do you all get the line drawings to look right? Mine looked good until I posted it.
Thanks,
Charlie
