AB SLC5/03, DF1 cable length
Mathias
Feb 2004
20
hi all,
can anyone tell me how long i can make my DF1-cable (the length the 1747-cp3 has is not enough)
and if this should by quite short, how long can the branches be on an AIC-network?
thanks in advance,
Mathias
DF1 on RS232 can reach max 12 meters (sometime I have seen 15 meters for RS232).
You could extend the length with isolated RS232/RS422 converters.
DH485 (which I guess you mean by "AIC network") has a maximum reach of 1219 meters (4000 ft) from end to end. I dont think there is a particular maximum limit between nodes, apart from the total max reach of 1219 meters.
Df-1
I've run DF-1 about 65-70 FT. with NO problems on a 5/03. True, good practice is to go 485 but customer needed a 'cheap' fix.
RS 232 workaround
I had a customer that was using an older PC on a RS232 Comm port at 60 feet with no problems.The PC failed and we could not find a replacement on site that would work at more than 30 feet without intermittent problems. What a troubleshooting nightmare. We moved the PC to be able to use a 30 feet long Comm cable. We then added cable to the keyboard, mouse, and monitor to reach the original workstation location.
Does anyone know if it is detrimental to use a FULL straight through cable to connect these two. I know that the AB cable does not carry pin 9...
1,980
Tried a straight through 9-pin RS-232 and a null model cable. No luck so far.
1,557
Hi everyone, I am new to this PLC forum and I have a question about this new project I am working on. I have a testing machine running on an old...
1,895
Hi all, I've trawled the search for hours, but couldn't find a definitive answer on this. We have 3 x SLC5/03 processor configured as DF1 Half...
5,018
Hi, Can you communicate to a PLC on the RS-232 port (DF1) after changing the protocol from DF1 Full Duplex to DF1 Radio Modem using RSLinx? I...
7,592
