AB Ultra3000i error E27
CB_182
Oct 2008
England
29
Hi everyone, I'm looking for some help with a 5kW ultra3000i. I recently replaced a drive which was around 6 years old (version 1.16) and recieved a service exchange, version 1.52. Initially the drive worked fine but after an hour or so it faulted out with E27, "axis not homed", after homing it would continue to do this every 30/60 minutes. I was sent another service exchange unit (1.52) but this was the same, while waiting for the 2nd unit we had the 1.16 unit repaired, this has been fitted and is running fine.....?
Rockwell weren't sure why both units faulted out and said there was no reason why E27 should come on on this version and not the original ?
Any help or advice welcome
Kind Regards
CB
The E27 error occurs if you try to initiate an absolute motion profile and the axis has not been homed. I haven't seen this happen while a machine is running but we did have an issue where the E27 was popping up on a certain Ultra every time the main power was switched on. This particular servo had an incremental encoder so the axis had to be homed at every power-up. The PLC would set the home axis command and wait for the axis homed signal, then start the first motion profile. Well after much screwing around I discovered that the Ultra had a faulty output and the axis homed bit was flickering before the servo had actually been homed. Bad transistor maybe? Rather than repairing the drive I just put a timer on the corresponding PLC input to filter out the flickering.
Hello all, I am brand new here :cool:. I'm limited in my controls knowledge but always trying to learn more. I recently started working at a...
354
Hello, we have Ultra3000i drive(2098-DSD-HV050X-DN) with motor allen-bradley (MPL-B4540F-M) and smart encoder, indexing mode. We had defect at...
924
Hello, We have a project we are working on here at the plant. 2 AB Ultra3000i with devicenet, SLC500 5/03 with devicenet scanner. I read the...
3,757
I have an Ultra3000i Allen Bradley drive that went bad, I have a backup of the parameters and after replacing the drive I was wondering how to...
1,394
Hi, I am trying to connect to an AB 3000i servo drive through an SLC 5/04 using a 1784-U2DHP USB to DH+ converter. The servo drive is connected to...
3,861
