ABB DC Drives
TLearnC
Dec 2010
Pittsburgh
I am communicating to several ABB DCS-600 drives via PROFIBUS. I am able to control the drives just fine. However, since these are DC drives, they also have field drives associated with them. The problem that I have is that my PROFIBUS network is only connected to the armature drives, and not the field drives. If there is a fault on the field drive, I want to be able to reset it via the PROFIBUS link.
I have read in the ABB manual that you can send the ON command to the field drive to reset a fault. It says that you can do this via the FEX link between the two drives.
Is it possible to set some parameter in the armature drive in order to reset a fault in the field drive? Obviously, according to the manual, sending the ON command would be adequate. Is there such a parameter in the armature drive?
Thanks.
I have an ABB ACS580 drive with an FEIP-21 communications module. It is currently configured with an IP address and I have verified communications...
1,615
I am using a Red Lion DA30D Gateway to control 12 ABB drives via RS485 from a M580 PLC. I send -20000 to 20000 as the speed Setpoint to each...
2,352
Guys, does anybody know the difference between various control panels for ABB drives? I couldn't find any explanation on ABB site apart from that...
1,900
Hey guys, how to fix problem on my abb drives with a fault 101 on panel?
2,103
Just wondering if anyone has used an ABB branching unit (NDBU-85C) to link multiple drives. I was hoping to monitor multiple drives on one...
1,451
