ABB Procontic b
GEOFRA
Jul 2002
Nicosia
99
I have a project to replace an old ABB Procontic b PLC. I wonder if anybody has experience with this system.
I have the following questions:
1. !E03.01 & S00.00 = T00.00
In the above instruction if input E03.01 AND register S00.00 are 1 then Timer T00.00 begings timing but when will T00.00 go on?
2. !E03.01 & T00.00 = S00.00
The above instruction checks whether T00.00 is on or it turns T00.00 on?
3. If I have output cards with 8 outputs each.Lets say outputs are numbered A03.00 to A3.07. Can I use A03.08 to A03.15 as internal flags? If i use them, when A03.00 is on, A03.08 is also on or they are completely independent?
4. 0100 ! E03.001
0101 & S01.01
0102 =S T00.00
0103 #020E3
In the above instruction if E03.01 AND S01.01 are 1 = sets the duration(20sec) or it also starts the timer?
Procontic b system
Hello,
do you have the programmer software for this PLC?
Thanks, Patxi.
Hello Everybody! I'm looking for a programming software for a very old PLC, an ABB 07 KR 264 from the Procontic K200 series (907PC322 is the...
5,695
Hi, Can anyone help me with this old DOS programming tool for ABB Procontic PLCs..... I have the original PLC code, programming manual and can...
4,032
Hello all we have 4 plc ABB Model Procontic 07 KT 93 R101 connected Together with a coaxial cable the network named is CS 31 and as a Master...
5,227
Hi.. we have second hand machine with Procontic PLC and currently we start to convert to SLC. How Counter and Timer works? How to find conter and...
1,627
Hi All, my name is Attila Fortner Engineer at VALENCIA VENEZUELA I have the ABB Procontic PLC software for K200 plc, it's name is 907 PC 20. But...
4,323
