ABKF2 not compatible with Win2008 Server
RobinWang11
Jan 2009
Victoria
36
Hi All,
I got a project which needs to upgrade a old Intouch application to 10.1 version. The new OS is Windows 2008 Server. When i try to install ABKF2 driver, i got an error message, and i shows not "compatible".
Anyone have samilar experience? What I should do with this case?
Does ABCIP works? Or, Do i have to install an kepware OPC server? Because it is a upgrating project, i really don't want to have a Kepware.
Thanks a lot,
Robin
I don't think ABCIP would work, but the DA server version DASABCIP Version 4.1 works fine in Windows Server 2008. This is an Ethernet driver, though, whereas ABKF2 is a serial driver..
Do you have an RSLinx (anything other than Lite) license? Because then you can use its OPC server. Maybe get a Net-ENI to use the DASABCIP driver.. What processor are you connecting to? Is it on a network or standalone?
We have two SLC5/03 and one control logic PLCs. The first phase of this project is get the wonderware upgrated (make it works with all exsiting PLCs), and then we will replace two SLC5/03 with Compact logic PLCs.
Do you mean there is no driver in wonderware i can use with Windows 2008 for serial communication? Or, the only way is to have an OPC installed or ENI card?
BTY, the client does not have a RSlink license.
Thanks.
Well, I haven't had to connect over serial with Win7/2008 yet.. I don't know of any good/free option offhand. Have you contacted Wonderware? They may have a solution I am not aware of.
on a XP PC we were using ABKF2 to talk to a motion controller on a DOS PC emulating PLC5. This driver would not work on Windows7 so we tried the...
2,021
Dear All, I have a problem that I can't communicate my MicroLogix 1200 (serial RS232) to Wonderware InTouch using ABKF2. I don't know what's...
2,463
All I am using Wonderware v10.1 and the ABKF2 IO server. If I address one tag for physical IO like I:13.0 as Tagname Input_13_00 (I:13.0 is a 16...
2,904
Hello, I´m new with the intouch application. It´s a project that I took from another partner. It´s an advanced project. My question is that...
5,414
Dear All, I am trying to install ABKF2 driver from Wonderware device integration CD. but i am getting system error. A error msg is attached for...
1,724
