about Kinetix6500
angi
Jan 2010
us
361
Hi guys
One more question for Kinetix6500:
I am using ControlLogix5000 to work with 6500, I need to update the setting for "System Configuration" parameter, how to do that? what software I need to use?
thanks
I guess I am not following you. I updated all the parameters through RS5000. Some of the parameters you need to be either be in programming mode or send a servo off command.
am talking about how to update the parameters such as "System Configuraton","Reset type".
thanks
I'm not exactly sure of what you are asking, but I believe you are looking for the GSV (Get System Variable) and SSV (Set System Variable) instructions.
Hello All. We had an incident yesterday where the hard overtravel limit switch was stuck, which we didn't find out until some wasted time...
1,503
Hello, I have a application where I accelerate/deccelerate tires mounted at a spindle. That tires can be different sizes with different inertia...
1,255
