AC coil snubbers
rpoet
Jun 2008
New York, NY
536
All,
Please check my thinking. I'll be using zero-crossing solid state relays to fire some 120VAC solenoid valves. Since the SSR's are zero-crossing turn on/off, I shouldn't need transorb / snubber protection, correct?
I don't often deal with AC coils, and I'm used to putting diodes across DC coils.
-rpoet
First, you need to check the specs of your SSR to see if any protection is built-in. Sorry didn't think of this in my first post.
Here's what Crouzet says about their SSR's. (Link )
"What is a snubber network and when would I use one?
A snubber network is a resistor and capacitor in series and is placed in parallel with the output of the ssr. Typically snubbers are required when the relay is placed in an environment that has electrical noise. Most manufactures incorporate a snubber network into their ssr’s. Crouzet uses an inductor along with transorbs to fill this role instead of a snubber network."
A TVS alone may not be enough, as shown in this paper from Crydom.
An RC type snubber is the first choice.
This type has an RC and MOV in one package from FM.
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
1,004
So I'm having issues with a certain rung and one of my coworkers mentioned it may not allow the signal past the latch coil. For example in the...
27
3,770
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
900
I thought of this before and always did like everyone else and put 2 relays next to each other and wire the contacts parallel, but... Has anyone...
1,195
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,880
