Ac inverter
vadi
Jul 2011
c
how can i use an ac inverter having an output 3x 0-32Vac to run a 3 phase motor of 240/415 V ?
Are you sure it is a 32VAC inverter ???
Can you please give make and ref. of the inverter.
So then how do i run a 3 phase motor of that high rating using a dc battery voltage of 48v
Again, you don't. That is simple.
You could, I suppose, make a fairly inefficient supply by first building an taking your low voltage drive, probably filtering the output, running it at a constant frequency, stuffing the output to a step-up transformer, then using the output of that to feed a properly rated VFD, but I wouldn't bother.
I'm sure he can handle that. :D
vadi- bottom line from the limited information you have given is that what you are trying to do is not practical. I'm sure there's ways of getting there, but would be way more costly than just replacing the motor or matching the drive.
A better idea would be to give us an outline of the application, and all the items you have to do it with.
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
96
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
560
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
103
Hello I am writing to request assistance with obtaining a specific GSD file for our Mitsubishi inverter type A800-E, which is connected to our...
442
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
232
