Accessing a redundant OPC server from Indusoft
ElVale
Jun 2010
Cartagena
23
I have two identical Kepware OPC servers with the same tags and the same values. How can I configure Indusoft to access one of them and then switch over to the other OPC server in case of a communication fail? I'm trying to achieve the same results as with RedundancyMaster.
195
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
419
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
596
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,732
I'm looking to replace an AB PanelView 600 2711-K6C2 HMI with a C-more EA9-T10WCL. The PLC in the system is a SLC 5/03, which is staying. I...
1,255
