Accessing SD Card via Ethernet/IP?
Iridescence
Aug 2013
San Francisco
Hello all,
I've been thinking of using an Allen-Bradley CompactLogix 1769-L33ER PLC to do data logging by writing to a circular/ring buffer in the PLC memory and then transferring the data to an SD card when triggered by an alarm or event. The purpose of this is to be able to have high-frequency data from about 2 minutes before and after an alarm has occurred.
I would like to be able to access the data on the SD card remotely through the internet. Do you know of any solutions for accessing SD card data in Allen-Bradley PLCs via ethernet? My company currently uses Indusoft Web Studio as its SCADA solution.
Thanks so much.
do you mean your scada system is not equiped to handle high frequency data directly from the plc?
bce123 : Currently our SCADA system can only log one sample per second, but we are currently looking to sample at at least 20 samples per second. That is why we have to do the data logging on the PLC.
Wow thats slow there is a company close to you: Inductive automation. they have a product called Ignition that you should look at. I am in no way connected to them just a big fan of there data collection abilities
197
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
420
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
596
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,734
I'm looking to replace an AB PanelView 600 2711-K6C2 HMI with a C-more EA9-T10WCL. The PLC in the system is a SLC 5/03, which is staying. I...
1,255
