Acopos 1320 error no 7211
e.elgohary
Sep 2014
rabigh
Dear gentelmen
i need your help for an issue, i have acopos 1320 servo drive when i run it with high speed some times give alarm 7211 (dc bus voltage drop) the problem is not regular some time happens some time not.
When it happens i shutdown power for 5 min after return it, it works again
please support me
Do you have just one servo drive or do you have multiple in the same cabinet? If you have multiple you can wire the DC bus together so it is shared (this works on model 1022 and 1045 anyway)
dear my model number is 1320, and i have some fear that the one with the malfunction affect the other one, i make a search before that there is capacitors need to be changed but i can't determine where is this capacitors
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
454
I have an acopos 1320 in our plant that repeatedly throws 4005 Code? Can anybody help me out to figure what's causing This? I looked up the...
3,634
Does anyone know what waiting for telegram error means? Its one short red error light blink every three seconds on the drive. Thanks!
2,296
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
146
Hello all, i am new to the servo drive and this brand also. i installed the automation studio v4.12. i have to configure drive with plc B and R...
377
