denkap Member D Join Date Sep 2019 Location ct Posts 2 Sep 3, 2019 #1 how to wire a jog push button to unit and switch from run to jog mode
Dhitzfelder Member D Join Date Feb 2019 Location Montrose, Colorado Posts 52 Sep 3, 2019 #2 Wiring depends a lot on the system you're working with. You may also need another switch for "Manual" mode (or replace a 2 position RUN/OFF with a 3 position RUN/JOG/OFF switch). Are you using a PLC, and do you have the software to reprogram it?
denkap Member OP D Join Date Sep 2019 Location ct Posts 2 Sep 3, 2019 #3 i am using a 3 wire start stop button presently but need to add jog function for machine set up
BryanG Member B Join Date Feb 2005 Location Manchester Posts 1,996 Sep 4, 2019 #4 I think parameter 1010 JOGGING SEL is where you want to be looking. So you could change DI4 from a constant speed selection to a jogging input. Hopefully an ABB expert will post.
