Actual Elevator Question
Mike,
I'm curious as to the average amount of IO in, say, a 4 level cable lift
About 90. Something along the lines of a 205 w/9slot base, 240cpu, 1 counter module, 3-16pt inputs, 3-12 pt outputs, and 1 8pt output.
Rod said:
And do they actually measure mass?.
Yes, but only/usually on high speed-high traffic installiations like busy office buildings. There's a strain guage on the crosshead that measures the load before the car starts to move.
When six 3 foot wide people step on and I see the car floor lower than the door sill - I be heading for the stairs!
Good idea... There's a positioning system mounted on the car that should relevel the elevator. If the elevator is below the floor (more then 1/4" or so), there's a problem. Take another elevator.
Why is the configuration IP different from the actual IP address still able to run normally?
848
Hi all, Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current...
1,115
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,977
Hello all! I have a problem. We are using SINAMICS V20 (6SL3210-5BB17-5UV1) to move a car tire with a motor up and down. The main principle is...
1,097
Hi all, I'm working on an FX1S-10MR-ES PLC where there are 6 inputs (X000-X005) and 4 outputs (Y000-Y003). I used the programming from another...
1,993
