AD ethernet/ tcp/ip questions
tommy23t
Nov 2003
New Jersey
136
Hi All. Hope you can help. I have spent all day on this and still nowhere. 🔨
I am using Automation Direct (Host Eng) ECOM module on a DL-260 cpu and can "talk" to it just fine from my desktop computer, running XP Pro. I need to do a "dog and pony" for a client, and need to run the application off my laptop. The laptop was just upgraded to XP Pro.
My problem: (baffled AD support also) I can run NetEdit, and get an initial error of 10061, can't find connection. I continue, the main screen appears, and I switch protocol- it detects the module in IPX only. It runs a cpu test, and it comes back as a 260 cpu, all working. Change to tcp/ip, and nothing. I checked all my settings, ip address, ect., duplicated the ones on my desktop. I cannot ping the ECOM unit, all fail. I did a loopback test, the ping passed.
Any ideas?
tommy23t
You don't have a software version problem, same version desktop and laptop?
Really take some time to study what the 'DS400.ini' file does. Tweak it. Focus on that guy.
John
Compared the 2 files- made some changes, no help. I did create a link thru Directsoft for the ethernet link, and connected fine to PLC, able to monitor and make changes. It must be something with Windows, I have all firewalls disabled, still banghead
Tom
Yes, Thanks John. Was there yesterday, tried all settings. Really strange. Like I said, all settings on my desktop are same in the laptop, take network cable out of laptop and into desktop and good connection. Have tcp/ip installed, even found a winsock repair utility on another forum that cleaned out the winsock files and reinstalled the tcp/ip. Sounded good, didn't work
We are going to try to set up a local network here between the 2 computers to see if that will work. Man, this gets frustrating. Maybe it has something to do with Compaq.... So close...
-Tom
FYI- John: found zone alarm was runnimg in the background- forgot all about it. uninstalled, all works now. Thanks anyway
-Tom
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
211
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
412
183
Hello, Sorry, my knowledge of communication protocol is limited, so thank you in advance for your answer. My question; I want to get 5 values...
878
Hi All, Trying to help a client who has a project that was started with Schneider STB remote I/O, but they are still waiting on the STBNIP2212...
1,951
