Add Flex node (ControlNet)
mbtoy
Sep 2005
xxx
We are using CLX5K L63 PLC(v15) with distributed FLEX IO
Is it possible to add New IO Module (New Flex node)
without stopping the controller?
Do you mean an entirely new adapter and I/O or just an I/O module to an existing setup?
You can't add modules to an existing setup but you can and a new node to your network depending on what you are using.
What exactly are you trying to do?
No.
RSLogix 5000 version 15 allows creation of I/O connections to 1756-series network bridges (1756-ENBT and 1756-CNB(R)) on EtherNet/IP and unscheduled ControlNet networks while the controller is in Run mode.
It does not support creation of those connections in Run mode to any other platform or device, including FLEX, POINT, or 1771 I/O.
Do you have a ControlNet installation that allows you to connect adapters without disconnecting the trunk cable ?
Just had to replace a powerflex 525 in a machine that has a allen bradley compact logix L24ER plc. After installing the drive and setting it up...
2,784
Hi, I have to add a powerflex 4m VSD onto a controlnet network, at the moment we have a powerflex 40 with an controlnet comm's card 22-comm-c...
2,486
Hi everyone, I'm new to work with flex processors. In my plant L34/A processor is being used. From that already flexbus local is configured. I...
2,593
Dear All, I am intermediate to using the RSLogix500. My project is concerned to add PowerFlex 700 drive that is communicating over ControlNet...
5,035
Hello all, New to the forums and New user of Powerflex drives. I am currently working on a project which will include RSLogix 5K, 3 Powerflex...
4,997
