Adding Comms to GE9030 with 313 CPU
keithkyll
Jul 2005
Heath, TX
2,033
I'm servicing a machine with a IC693CPU313W CPU. This is the low cost embedded type. Per Steve Bailey's post # 2 here in this thread, I can't use an IC693CMM311 Serial communications adapter to add a serial port.
Quickpanel HMI connected to the serial port, leaving nothing to connect PC.
Can I add an IC693CMM321 Ethernet module to communicate with Proficy ME?
What other options do I have?
Want to Start, Stop, and monitor values with HMI while monitoring operation with Proficy ME.
I guess I could start it, then connect software to monitor, and use overrides to simulate HMI.
Adding a module seemed easier.
Hi, Im wanting to add an ethernet/ip adaptor (an omron nx-eic202) to a logix system. The Logix plc is a 1756-L61 Rev 15.4 with a 1756-ENBT/A Rev...
2,384
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
302
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
101
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
171
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
134
