Adding DI card to Turck BL20-GW with RFID-2 card.
unsaint32
Oct 2012
minneapolis
365
We have a PLC system running a conveyor. The PLC system includes Turck BL20-GW with RFID-2 card. I am about to add a DI card to the BL20-GW. The DI card will plug into the side of the RFID-2 card.
My question is, can I do this while the system is up and running? Or should I kill power to the BL20 first before I plug in the DI card? I know I can do that for replacing cards in Controllogix PLC.
Thanks.
The Turck BL-20 line of I/O is not "Hot Swap" capable. Please shut it down first then make your changes and power back up.
thanks Russ. Just to be clear, what I am trying to do is just to add a DI card to existing setup (GW and RFID card). would it still require power down?
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,608
Hi, I've run out of analogue input channels on my Q68AD-G module. If I add a new Q68AD-G module and install it into a spare (blanked-off) slot, it...
1,374
Hello, Fairly new to PLC programming. Have a question in regards to a 1734 Point I/O rack and the built in tag structure in Logix Designer. I...
2,167
Is there a way to add a Point IO card to a project with a control logix processor (version 30 or 31 I believe) while online and in run mode...
4,431
Hello all. I have a job to add a 1794-IE8 Card in slot 5 on an existing Flex IO Rack which uses a 1794-ASB communications module, which...
3,039
