adding new screen to pv550
muds
Apr 2014
karachi
71
hi all ,,,
iam new at pv550 2711-b5a5 programming,,what i want to do is,,to add new screen to my pannelview and call it from my prograaming.
can any one guide how i add screen and called that screen from any input.
thanks in advance,,!
To add a new screen to your PV project just right click on "screen" in the project tree and double click on new.
To control the screen number thru the PLC see picture below on how to use the Control Tags for screen control.
hi mickey and all,,!
i tried ur way but not know how i can cal lnew screen from allen bredly programe? can anyone guide how i get screen adress of pannel builder and call that from input,,
thnks in adavnce
thnks in adavnce
Your new screen will have a number next to it, in my post above screen #1 ( Alarms). Create a tag ( see my post number 2) polling an integer within your PLC, by putting a value of 1 in that register the PV will poll that register and call up screen 1. You will have to put a zero in that register to release control back to an operator so he/she can change screens manually again.
several questions for you.
#1 what is the firmware / series of the panelview you have.
#2 what is the panelview programming software you have?
part number and version.
#3 what is the plc you are trying to connect to?
#4 what is the plc programming software you have.
#5 what interface cables do you have for the panelview and plc?
this will help us with your solution.
regards,
james
hi mickey and james
i am bit late to reply but many thanks for your supporting reply,,,mickey your reply always lead me to completion of job...!
task compleated,,,cheers mickey and james:beerchug: and :site:
regards
muds
dear mickey and all,,!
i had come through this error when programming pannelview550 cat-2711-b5a5 ser-E Rev-a Frn-2.01
cat-2711-b5a5 ser-D Rev-b Frn-1.07
no error accured when programming cat-2711-b5a5 ser-E Rev-B Frn-2.01
so ,,sir what differnce in those given pannelview's 550. is there any way to decrese size of programme file or what i am doing wrong. or any other way,,!
please guide me,,pic attaced of error
thanks in advance
muds
Before you tried to download the program did you change the catalog & revision numbers?
You probably would have gotten the error about memory usage when you changed the cat number.
The only thing I can think of for reducing memory size is to cut down on graphics in your screens if possible.
Version 1.07 was the very first release of the PanelView 550.
It was, at the time, very popular. But it had a smaller memory size, which RA increased a few years later.
You'll find that any version 1.07 firmware PanelView 550 will forever be at 1.07; they do not have enough memory to be upgraded.
It was possible to configure PanelBuilder32 to remove some of the information from the project to reduce the project size. This has the side-effect of making the application file non-uploadable.
But that was in 1995, and it involved using version 2.60 of PanelBuilder32.
I recommend removing any unused text or graphics from the application, or getting a v2.x or newer terminal.
If you want to try to use the very old software method, it's described in the RA Knowledgebase:
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/14431
Hi,can you help me again? complete novice to PLCs. Using GT Designer/SoftGOT1000/Developer. Working on adding some Water Cooling parameters to an...
1,203
There is a screen saver function for the Panel view 5310. It utilises a AB logo splash. I would like a custom image to be the splash for the...
1,283
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
28
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
51
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
116
