addressing OMRON PLC (cj1m-cpu12)
Jul 2012
KUWAIT
18
guys please i bought cpu (cjim-cpu120 with input modules (CJ1W-ID262) and i wrote the whole program but i have a problem with addressing if there's anyone know how to address the input switches to refer to the points that at the modules...
thanks guys
use the right click on the symbols tab
als make sure you have the cards set up
The CJ1W-ID262 module will use four consecutive CIO words.
The starting word location will depend on the physical layout of the hardware.
Hope this will help.
@iant thanks alot for your help i'll try this method once i back home but is this will give me the start bit depending on the place of unit on the rack ? and if that will give me all the inputs address you know CJ1W-ID262 is 64 input so this will give me from(0.00-3.15)?
@gtsuport please give me example if i put the module in the first place nearby the cpu what will be the start word ? what i should exactly write in the address blank?
that is correct with the start bit. slot 1 = 0.00~3.15
because it it a high density card the setup is important
Hi Anyone please hel[p me to understand the OMRON PLC addressing and the memory areas. Some sample programs would be very useful. Thanks Regards...
1,758
HI EVERYONE I need your help to refresh my memory on omron plc. The plc is cpm2 with 32 I/O having: 0 ch, 1 ch, 10 ch & 11 ch I am rather...
2,768
hi guys, just new to plc and I'm trying to understand a program that a previous employee in the company did. when i looked at the I/O comment in...
2,961
If anyone can assist me in my folly I would surely appreciate it. I am creating a program for a small control panel and find that I can't get any...
8,327
Hi all, I've only been learning Omron for a couple of months now. Used AB and Automation Direct. Today I went to start a program and set up my I/O...
1,906
