Afi's
showshocka
Mar 2011
USA
510
Good morning all. I'm just curious of what the use of using an Always false instruction (AFI) if the rung will never be true anyway? The best I could come up with is for T/S, but I see lots of projects with theses instructions. I'm sure people in the past was not that careless to leave these T/S rungs in the project.
Don't be so sure that they weren't careless.
Also, I've used them in the past when I had code that either had to be taken out for a temporary basis (that usually becomes permanent) or had not actually been implemented yet.
I've done stuff like special sorting or rejecting that needs to be done only once in a while and I've used bits like AFI to diable the code.
There is a rather lengthy thread on this topic from a while ago that opened up a big can of worms.
Personally I use them to disable code that I want to de-activate, but not recreate in the distant future. I use bit addresses with descriptions to temporarily disable logic.
Be careful here a "AFI" does not disable the rung. See links below
http://www.plctalk.net/qanda/showpost.php?p=8258&postcount=3
http://www.plctalk.net/qanda/showpost.php?p=337526&postcount=6
What is "T/S"?
You're correct, it does not disable the rung, it turns it false. When I leave logic for later use I like to still keep control of it (by scanning it), so I do not jump around it, or put it in un-scanned files, unlike some of my colleagues...
Hello all, For the life of me I cant understand why this output (B3:1/11) keeps on flickering on and off.. I have an AFI in front of the rung...
1,673
Is there (AFI) instruction in DL or equivalent? Thanks
1,715
In RSLogix5000, how can I tell if a project has AFI? And does it point me to which routine/rung has it?
3,263
I am looking for instruction like AFI in cxprogam ladder logic.
2,222
Hi, I'm having problems with an AFI. I copied and pasted a rung's logic, made a single edit, and AFId the previous logic in case they wanted me...
3,320
