AIC+ w/ML1500
hamm3r1
Oct 2016
indiana
19
I need to go online with a ML1500 that is connected to a AIC+ along with a panelview. From my laptop to the AIC I connected with a [FONT=&quot]1747-CP3 cable and tried AB_DF1 driver but no luck. Any help would be appreciated[/FONT]
Usually when a AIC+ is used the protocol is DH485.(not always)
Do you have the offline file for your ML1500 to check how the ports are configured?
Can you provide the complete catalog number of your PanelView?
Does your laptop have a real serial port?
Which RSLinx Driver works with a 1747-UIC.
Good Friday to all.
I'm trying to connect through a 1747-UIC to a AIC+, port 1, to a SLC503 on port 3, reconfigured for DH485. Which RSLinx Driver should I use and are there any known issues doing this.
Thanks in advance.
I have ML1500 and PV1000+. I would like to display the parameter value in the ML1500 on the PV1000+. The following configuration is impossible or...
3,923
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,790
Hello! I'm curious if anyone has used ReeR / Mosaic Safety Controllers and can give a short review on how you liked them? I've never used them...
581
I have the following Items connected for DH-485 per the drawing. SLC 5/03 HMI: Automation Direct EA9-T10CL+13Y19B054 1747-AIC #1: connected...
3,050
Hi all. i need an a advice. I use PV800 -T4T or T7T ( to a replace for an old PV550 ). But I have a problem " create communication with PLC...
1,731
