Allen Bradley DeviceNet scanners 1747-SDN
tombobek
Apr 2002
Hi !
I have configuration with two DeviceNet scanners 1747-SDN in one ruck with
one SLC processor, and I have a problem :)
I use PLC Ethernet port for communication with this scaners, so it's
pass-throug and RSNetWorx for configuration. Temporary i have one PanelView
600 connected to first scanner and second one connected two second scanner.
When I put driver for device net in RSLinx for first scanner all is ok, I
see scanner and panelview in results window. But when I put second driver
for second scanner I see only one device on node 00 with descritpion:
unrecognized.
Is there sombody who knows, how I can configurate this ?
I don't know if you can configure two 1747SDNPT passthrough drivers for the same processor; that might be your essential problem.
More likely it's a configuration problem with one of the scanners. The passthrough driver requires special configuration of the "M0" and "M1" files in the Advanced I/O Configuration window of RSLogix 500.
Default M0/M1 file size is 256 words. To use Passthrough with 1747-SDN firmware 4.26 and later, set both files to 361 words. Version 6.02 firmware increased the size of the messages that could go through the Passthrough driver (such as PanelView downloads), and to do that you need to set both the M0 and M1 file to 395 words each.
Passthrough is a pretty slow way to get onto DeviceNet.. I use a 1784-PCD card and find the cost is well worth the time I save.
Hello all, is it possible to reset a faulted armor block thru the plc? I know I can reset the devicenet card, and some devices thru the PLC, but...
1,461
Needing RS Logix 5 programming examples for communicating (PLC 5/40E) to multiple Ultra 100 servo drives over devicenet. The user manual for the...
1,309
Hello Everyone, I am trying to find some article and watching a youtube video to understand the concept of DeviceNet and can't find enough...
5,067
I'm trying to commission a DeviceNet network between a 1756-DNB scanner card and a Toyopuc DLNK-S2 DeviceNet card. I see both the scanner and...
3,332
Hi, I'm not very experienced on Allen Bradley and i'm trying to solve an error 78 showing on a 1747-SND. The PLC is a SLC 5/05CPU. the error...
8,717
