Allen Bradley Kinetix 300 open collector outputs
lurby
Mar 2005
32
I am using an Allen Bradley Kinetix 300 servo drive with the Safe-Off function. I would like to utilize the Status of this to verify that my Safe-Off is functioning.
All of the outputs on the Kinetix 300 including the Safe-Off Status are "Open Collector" I have never heard of such a thing before. I have searched the web but can't seem to find an accurate way of setting this up without going to Radio Shack for electronic parts. What am I missing?
Why can't there just be a relay output or a 24VDC output?
Can I turn this open collector output into a 24VDC signal so that I can at least fire a relay?
Do you want to monitor it with a PLC It is a sink output and should set it up to sink an input on PLC
I believe it sinks to 0v so your input would be set up with the 24vdc on the common and the input going to the sink output on the Safe Torque card. Also your commons need to be tied together if the signals use different 24vdc supply. You could probably sink a small relay for that mater I dont know what the current draw would be. By sinking you are able to handle more current than sourcing.
I connected it and it works!
24VDC+ to PLC input common, STO Output to PLC input, 24VDC- to STO common.
Thank you for your help.
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
172
Hello, I currently have an Allen-Bradley Kinetix 350 servo drive, 2097-V33PR5-LM and servo motor, MPL-A230P-VJ72AA. What are the correct AB power...
2,552
Hi all, I've mostly used the Allen Bradley Kinetix 5500 servo drives so far, and my distributor suggested me giving the new Kinetix 5100 a try...
2,628
Hello, My customer wants me to come out and look at this servo drive. See attached picture. I am not at all familiar with this Allen Bradley...
26
8,544
Hello everyone, I have a problem with a Kinetix 6500 which gives a message: INHIBIT S04…COMMUTATION NOT CONFIGURED I checked the manual but not...
9,716
