Allen Bradley Panelview 550
Thanks for all the help I got lucky someone gave me the six disk set for my panelview so I loaded the softeware and I am using a usb to rs232 converter cable connection and I still can't connect to the PV. The panel view 550 is model number 2711-t5a1l1. Can it be the the USB/RS232 automation direct
EA-MG-PGM-CBL converter be the problem it works on eveything else I use it on or am I forgetting something.
Rudy
Your PV supports RIO protocol on it's comm port. It also supports DF1 protocol on it's AUX/ printer port for upload/download. You can use the Aux port as long as it has not been configured for printer use.
The most recommended USB to serial adapter is the Keyspan USA-19HS see link.
You will also need a straight thru cable connected between the USB to serial adapter and the PV.
https://www.google.com/search?tbm=shop&q=Keyspan USA-19HS
Another method to upload/download the PV's program is to use a memory card. See PDF below
Sense this is a RIO PV what do you plan on connecting it to?
"Six disk set" ? PanelBuilder32 (and for that matter, any Rockwell software) hasn't come on diskettes for more than ten years. It's entirely possible that your PanelView terminal firmware is not supported by this old software.
PanelView Standard terminals have a "DCE" style serial port. This is pinned with the Rx and Tx terminals opposite of a standard computer "DTE" port, so you need a straight-through serial cable to connect to the PanelView.
Most of the time, you use the RSLinx Classic communication drivers to connect to a PanelView, rather than the old direct drivers that were part of the PanelView Transfer Utility in the 1990's. Those direct drivers may not work with USB communication converters.
Hi Having issues with a older PanelView touch not working. Screen is connected to a Desktop computer. screen used as a display with touch...
126
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
218
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
739
Hello, I have several SLC-500 based systems. The user interfaces are PanelView 2711-TC1 touchscreens with firmware revision 3. I purchased a...
2,082
i was trying to run a .mer file which i have uploaded from a running pvp1000 same model. when i load it on new pvp1000 it shows " the terminal can...
2,261
