Allen Bradley SLC 100
These controllers have been obsolete for quite a while. You need an RS232/422 converter to communicate with them, which is no longer sold. The DOS-based programming software is also no longer sold or supported. There is likely to be some aftermarket or gray-market supply for both, though. There have been several PLCTalk threads about the communications interface and alternatives to the original A-B hardware device.
I would strongly recommend purchasing a modern controller instead of attempting to learn and commission this very old controller.
I am looking for the full version of the Software, thank you for your help
382
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,155
Hi all, Client has a hard faulted SLC 5/05 Revision B CPU, and I'm wondering if a Rev C or D can be directly swapped. Thanks!
1,129
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,137
2,255
