Allen Bradley SLC 5/05 VPN
CrabMan
Dec 2008
Karachi
We have to connect to a remote site through VPN(pptp), we have set up a VPN server on windows xp by allowing incoming connections and opening ports 2222,44818,1723. the network topology is: SLC 5/05 and parker PS10 powerstation and VPN server are connected to a DLINK ethernet switch, and the switch is connected to an ADSL modem. the PC(vpn server) can see the slc 5/05 processor in the rslinx and can program and monitor both offline and online, however when i try to connect from somwhere else, i successfully connect to the vpn server and then i can ping the plc and all other IP's on the network of remote site using local IP's (192.168.*.*) but i cant program the plc remotely.
P.S.
1) when we open rslinx on the site (from vpn server), we see a PLC connected in the RSwho window and the description says SLC5/05 processor but when we remotely connect the description in RSWho says RSLinx API server/ not a slc 5/05 controller and the picture is not that of a plc it is something like a PC connected to plc
2)VPN server has been assigned a static IP given by ISP and a local IP 192.168.*.* to enable routing + it has only 1 network interface card
3) the plc's gateway address is 0.0.0.0 and when i try to give it the ip of vpn server it stops communicating with it too.
Kindly advice on this issue, any input will be appreciated.
Regards,
I am looking for the full version of the Software, thank you for your help
380
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,155
Hi all, Client has a hard faulted SLC 5/05 Revision B CPU, and I'm wondering if a Rev C or D can be directly swapped. Thanks!
1,129
Hello! We have a drum rotation machine controlled by a AB SLC 500. The drum rotation inputs comes from a encoder into a 1746-HSCE. We are using 2...
1,137
2,253
