Alley Bradley SLC5/05 tcp ip communication
peter.wong
Dec 2003
Hello All,
I had developed a tcp driver for the SLC5/05. I can talk to the PLC using the RSLogic with the current tcp setting in the PLC but cannot access PLC with my driver or with the internet access to its web pages.
Anybody knows is there any settings on the PLC that I have to set up?
Where should I go to enable/disable the web pages. (This might be related?)
Thanks,
Peter
In the 5/05's channel 1 configuration, there is a check box for "HTTP Server Enable" so I would assume its got to be checked on. It came up defaulted to on when I created a new program but it would be best to verify it.
Sorry, I could not find the tab in the RSLogic interface.
Another question is does anyone know whether the ip access control list exists in the SLC 5/05. If it does, where can I access it through the RSLOGIX?
Many thanks in advance,
Peter
If you don't see the checkbox for HTTP server in the Channel 1 properties tab, then you have an older 5/05 that used 10 Mbps PCCC based ethernet. You will not have any web pages to view.
I am just beginning to learn PLC i have this ladder http://imageshack.us/f/233/ladderw.jpg/ i take me about 30sek to write it down and it...
2,091
Hi i tried to convert this program http://imageshack.us/f/843/logixproladder.jpg/ 2 way traffic light from Alley to S7 but i cant seem to find...
1,573
i am doing a student project at the moment and suddenely the PLC are not response to the Touchscreen.... and i check the program and find this...
1,621
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
147
421
