Almost There Bar Code Reading.
bobwithdana
Dec 2003
california
239
I have a Keyence BL-1371 Laser barcode reader connected to a Keyence RS232 N-R2 Interface with my Flex-logic PLC Rev 13
Here is whats going on.
I can plug the serial cable into my laptop and with Hyperterminal, send the 'LON' laser on command and the 'LOF' and the bar cade reader will fire and display the barcode.
I can plug the serial cable to the Flex-Logic PLC and send the same 'LON' command and the laser does not come on. Thing is that if I press the test switch on the reader it triggers and the Flex-Logic recieves the code. Its just the trigger from the flexlogic that does not work.
I have tried many things. If I connect the Flex-logic to the PLC it sends the 'LON' command to Hyperterminal. I changed the flow control from off to 'xon' and 'xoff. I changed the command from 'LON' to one character 'N; and nothing seems to work.
I can hardwire the trigger to an 24vdc output but I dont think this should be necessary.
There is some difference in the way Hyperterminal is sending the 'LON' command compared to the Flex-logic PLC.
Thanks for any Ideas?
Bob
Hello. I am trying to receive upstream PLC to PLC comms data. The Messaging command has been previously set up and working. I am just trying to...
1,828
Hi all, Summary I am stuck at what I hope is the last step (see below) in trying to look at [Data Views] via a MicroLogix built-in web server...
1,724
Customer lost the hard drive in their scada pc running Wonderware. They were able to use thier nearest geek squad to get a backup of all the...
20
9,354
my company is clossing three yrs,,, and i tool plc back in college but now im stuck... im willing to buy stuff from ebay but i don't know what...
1,984
reading about another user posting about panelbuilder32 and a AB 300micro having problems with setting up comms am using Xp pro with sp3 useing...
2,279
