AN-X2-AB Factory Reset to Default
DCom
May 2016
Conroe
20
I purchased a used Pro Soft AN-X2-AB Ethernet Module and wanted to know what is the process to reset the module back to factory. I assume it has an address and is why I cannot open the Web GUI, when I type in 169.254.42.84.
I have changed my PC ip address as well to match.
Any information is greatly appreciated.
I've got a G4(board only)with a MMI port problem. I do not know the IP, but I believe that port works. Is there a way to reset the device to...
602
Hi, I am using an old PV550 from another process. The old set-up was using a 1747-KE card and I can`t (after trying for a while) connect to the...
16
7,490
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
113
I want to factory Reset my 5380 (5069-L310) I have here in home lab. Reason being I want to make a Internal How-To video for Setting the IP...
628
Hi all, I've read the thread below which is similar to my situation... https://www.plctalk.net/qanda/showthread.php?t=127711 But I am unable to...
701
