Analog handling with a Simens 312 Cpu
edda
Jun 2008
At the office
100
Hi all!
Ive got a question.
I did a progam for a 312 cpu that is used for a hydraulik press, and there is a joystick that uses 0-5V signal.
I have never seen the machine, but we tried the program on the hydraulik system before it was shipped away.
But now to the problem, the electric on the press company says that when they relese the joystick it takes a while before all the outputs to the valves releses (when he looks at the lamps on the output card). All that is done inside to program for this vales is comparing the input to a set value.
And he also says that the 0-5V signal from the joystick goes to zero real fast.
Is the 312 cpu somehow slow when it comes to hangling analoginputs or something compares to a 315 cpu?
I scale the input with the simens scaleblock FC105, to a ordinary floatvalue in a datablock. I checked the scaned cycletime in the cpu and it was also short so???!!
Hi all. Can anybody help? I am new to S7 and have been thrown in at the deep end. I need to look at a couple of analog inputs and drive an analog...
3,687
Hi looking to install a smaller less sophisticated PLC for fountain timing and also one analog pressure sensor which would be used to detect...
23
545
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
64
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
143
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
163
