Analog inputs
deltasoft1
Aug 2014
cape town
Hi all.
Very new to plcs and all things electrical.
My first problem is that I am stuggling to wire a DPA pressure sensor into a dvp-04AD analog input unit.
The pressure sensor is an npn out put type.
For the analog input there are 4 terminals per channel. Voltage v+, Current I+ , com and FG.
V+and I+ need to be bridged out as the pressure sensor out put is in amps.
Now i need to know. Must the analog out put go into the com terminal? And as the V+ I+ terminals are bridged out where must the +24v be wired to allow for the npn wiring of the pressure sensor.
Secondly
The range of the sensor out put is 4mA to 20mA. When setting up an analog input in wplsoft the input mode setting only allows for current input modes of -12mA to 20mA or -20mA to 20mA. This means that a large chunk of the digital data range of 0-1000 will be cut out. Is there some way to adjust this as the data range will start at 500 when pressure is -100kpa
Every thing i am using is a delta product.
Any help will be greatly appreciated.
The input card only needs two wires. Take the analogue output from the DPA to V+/I+ then DC- to COM. Find a 24V elsewhere to supply the DPA at DC+
Don't know Delta PLCs but you should be able to scale the inputs in the PLC logic. You would surely be doing that anyway so it's no great shakes.
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
34
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
156
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
118
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
253
I have a SLC500 5/05 and we have an alarm setup to monitor the status of the Analog Inputs we have wired to a 1746-NI8. We are using 5 of the...
2,823
