Analog Signal Spikes
junke715
Jan 2020
US
21
Hello everyone,
Im in need of some help and ideas.
Here is my issue
I have an analog signal input go into PLC, and whenever my pump was shutting down, this analog signal always spikes for exact 8mA. stays there for various amount of time. the set up is very simple, analog signal coming out from one of the analog output on a controller, and go into one side of terminal, and other side terminal is go into PLC analog card. I also have only shield ground for one side.
Has anybody run into this issue before?
Really appreciate your helps.
A first step would be to eliminate the terminals in the line and wire directly from the analog source to the analog input. Many times this fixes the issue.
Is the pump on a VSD? Where does your analog signal cable run in relation to the motor cables? I assume this analog is not from a flow meter or pressure sensor which would be directly affected by the pump process.
I would check:
Instrument cable screen grounded only at one end.
Cable routing as far away as possible from motor cables
Inside the panel from the terminals you mention, wire routing path is as short as possible and away from power conductors etc. If that's not possible you may need to take the screened cable directly up to the analog input terminals
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
260
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
303
I need assistance in the form of some example programs pertaining to analog read and write. Thanks in advance. Sangli
207
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,363
I need to change my program to increase a IP transducer by 0.5 psi every 5 seconds. I am making a automated pressure tester using a pump, IP...
1,062
