Analogue input to ethernet with PoE
DLMUK
Jun 2013
Southampton
311
I have a requirement for the following device:
Input:
0-50mV or 4-20mA or 0-10V
Output
Ethernet
Power Supply
Power over Ethernet (same as the output cable)
Does anybody know if such a device exists? Looking for something reasonably industrial rather than hobby type electornics.
thanks
382
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,024
Hi, I have a device which is giving out a 4 -20mA signal but the ADC's on the PLC channel do not match. The supplier is saying the channel needs...
766
Hi, I'm planning to install a new Analogue Input module Q68AD-G. It will inserted on Rack 0 Slot 4. When it's installed, will the code recognise...
2,438
Hi, I've got a Q68AD-G card (8 channel). I want to configure it for 0-10v analogue input. I've enabled the channel by using Un\G0. Then I used the...
1,842
