Another Siemens Indirect Addressing Question
First of all, I do not know the acronym AWL so I cannot answer that directly. I used Generate source but when I posted it the spacing was all out so the code portion I replace with a cut and paste from the FB itself.
Those semi-colons always have given me touble, especially in C. I have a real bad habit of forgetting them, and when I read the code I normally do not even notice them so it is a hard habit to break. Normally my compiler would catch that and I go back and add them in.
I am assuming AWL is the generated source file and anyone copying this file would need to have them in. I apologize for this, as I did not notice them as missing. If it lets me edit I will go bac and try to put it right.
I have to go to the office this morning for a bit but I will look over what you have post this afternooon. It sounds like a much better implementation.
Edit: It does not let me edit. I found the file 00003.AWL in one of the sub-directories of the project. I was wondering where they kept those source files. Not finished the morning coffee and already leaning. Thanks.
.awl is indeed the source file extention.
PLC > CPU > S7 Program > Sources
That's where you'll find it in the Simatic Manager.
That's also where you can modify it.
Just be very very very careful with the compile.
I really like the byte to bits and vice versa functions. Good example of the use of AR1.
A couple things in the FB that I did not think of. The use of |NOT| for NotAckd,and moving the bytes to INTs to use the compare. I wrote my own set of functions for comparing bytes.
Hi Guys. Apologies for the long winded script but I want to give you the full script I imagine some of you guys have been in the same situation...
2,255
Dear All, I have a machine of stone cutting CNC. with Siemens 810D system. I am very tired to maintain(Servo drive failure) it now wants to...
4,953
Hi guys I need to transfer a tia license for a couple of days from one pc to another via usb and then back again after wards. What is right way...
6,974
Yes, I'm sorry, I'm starting this topic again. In my defense, I promise I tried to read on this forum and using other sources to get a good idea...
4,329
Hi all, I need some assistance. Does anyone know if it is possible to or how to copy a HMI project from one program to another program...
4,934
