Another STL to LAD question....
uptown47
Feb 2008
Over there, next to those boxes
1,146
I'm still trying to translate ladder into statement list as I am trying to get better at understanding and writing STL. I asked a question yesterday regarding this but I've come across another puzzler...
The STL in Network 1 is what I'm trying to translate. My initial translation was in Network 2 but when I've downloaded the code and tried it, it behaves more like the code in Network 3. Can someone tell me which one is the correct translation and is there a way of doing the translation so that I can avoid this problem in the future.
ie. Is there any tricks you know of for translating efficiently between STL and LAD?
Many thanks for any help you can give me.
Cheers
Network 3 is correct. The STL you have posted looks like it was part of a SR latch but with the S part removed - this is why it will not directly convert to LAD. Remove the NOP 0 and it will.
Thanks Simon...
While I've got your attention could you look at this one for me as well..
Again, I've tried to translate it but I'm not sure if its correct.
The second line...
A(
O M0.4
...Threw me a bit.
Many thanks for your help mate
Cheers
uptown47 said:
The second line...
A(
O M0.4
...Threw me a bit.
I think there used to be a few more statements in the brackets.
If I'm thinking correct today then:
A(
O M0.4
can be written:
A M0.4
L D[AR2,P#0.0] Will probably correct me if I'm wrong...:D
I agree with you - hence the M0.4 should be in series with the N/O contacts. When you see brackets, initially replace them with a contact and then replace the contact with the logic inside the brackets.
A big thanks for the info everyone. And thanks for this tip Simon. I'll try and apply that...
(I'm sure there'll be more questions before I've got all this STL thing off pat).
Another question for you...
I've kept it in the same thread otherwise I'm going to end up with loads of threads all on the same subject...
Here's the picture, Network 1 is the STL and Network 2 was my first thought.. then, after changing to STL to see if it resembled Network 1 I had another bash at it in Network 3.
Network 3 is nearer but I'm still not sure if its accurate.
Can someone let me know where (if) I've gone wrong and also whether the second OR is round:
1) all the previous statements
2) just the statements after the brackets
3) just I 0.6
Help/pointers etc really appreciated as always...
Cheers
:unsure:
Peter
That would make sense mate..
I've just redone it in ladder the way you said and then translated it into STL and it translates:
A(
A(
A I 0.0
O
A I 0.1
A I 0.2
A I 0.3
AN I 0.4
A I 0.5
A I 0.6
O
A I 0.7
A I 1.0
A I 1.1
AN I 1.2
= M 90.0
A M 90.0
= Q 4.0
That's as close as I've seen to it...
Cheers
(y)
How would you write this... What I do is length/speed = time in ms, to be used for SFB4 L "speed m/min deel 1" ITD...
2,253
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
81
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
211
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
485
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
272
