SirCharles1
Good day all. I have a machine to automate. It is a 2-ton heat press. It moulds small plastic parts. The mould cycle is initiated after the operator "presses" two proximity sensors. The proximity sensors are wired to an anti-tie-down device (AT-GM-11KM) which only allows certain portions of the machine cycle to be initiate when the two sensors/buttons are "pressed". In the automatic mode of operation, these buttons will not be used and the machine will cycle through its operation automatically. Is anyone familiar with this device (AT-GM-11KM, made by Banner)? My intention is to install a switch that one can activate and switch between manual and automatic, and when it is in automatic mode, the proxy switches need not be pressed. Consult my pictures.
