Apacs does not reponse?
pacs man
Dec 2003
I been trying to config a server(NT) for DCS. But i can't get the Apacs real time server to run. every time i run the apacs exe file, a hourglass appears but disappear after awhile.No error code appeared.
I confirm the mbus_NET driver is correct and i using factory suite service pack E with a ISA M-net card. Should i install the M-net card first before installing the factory suite.
On the control panel, my m-net driver indicates operation. What's the different between operation and running?
Last but not least, anyone know any books on DCS.
Gee, I didn't use it in a looong time. Installed MNet card,
loaded software and it was working fine for me.
Unfortunatelly I don't have access to unit to try it out.
One thing we had problem with was to get redundancy work on
our PCs (at the time, we used super fast PII/266). Original
driver was ok with P150 or P166 but couldn't work properly
on machines running at ca. 200MHz or faster (even after few
changes in BIOS such as disabling CPU cache, lowering clock etc.). After while, Moore provided "temporary" solution
which was driver with lots of NOPs in a loop :p
Hello, Background: At my work we are migrating the old plant architecture from APACS+ to PCS7. This process has been ongoing for several years...
1,643
Hey all, I know this is a shot in the dark: I'm trying to setup a redundant pair of ACM controllers and I dont have any of the serial cables for...
1,160
Hello all, A group I am involved with is just completing converting a Siemens APACS control system over to an RSLogix PLC. The subject came up of...
1,235
Having an issue in which trying to communicate via modbus on an ACM+. I made the redundant serial cable myself, and verified it with my...
2,428
I have currently installed GE iFix 3.5 onto a Windows XP machine and trying to get comms to a Moore APACS system. I have the APX - Moore APACS...
2,869
