Array and PMCR
PZAN
Jul 2008
LA SPEZIA
I have to poll 3 devices on a rs485 modbus using an Omron SCU41-V1. I just implented an FB which calls a PMCR passing it two internal arrays (S and D parameters).
The problem is that the comunication doesn't succed in receiving the data from the devices.
I think that probably the problem in about the D array size.
Is it possible to use INTERNAL array as PMCR S and D parameters?
Could you help me?
Thanks in advance.
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
298
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
214
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
180
Hello everyone, I'm working on a project that involves controlling an array of nozzles within a CNC environment, where the nozzles travel along a...
194
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
465
