ASCII escape characters in string file?
JHarris
Jan 2006
Tennessee
48
I have a SLC 5/04 and a device that accepts ASCII commands. The commands use escape codes (such as ESC + STX + A). I'd like to save the seven possible commands in a string file for use, though I don't see a way to enter the escape codes. If I open a string file, I can't switch the radix to hex or dec.
Example: I'd like to store the ASCII equivalent of hex 1B0241 in a string file.
I can enter the codes in an ASCII data file, though the transmit functions apparently require string data type. I guess either a way to manually enter the codes (in string data file) or some logic to do ASCII->STR conversion is what I need. Did I miss an instruction to do this?
Try this
Referring to an ASCII chart, insert a caret (Shift+6) in front of the desired special character equivalent. Using "^M^J" will send a CR and a LF.
This works for everything except Ascii ESC, FS, GS, etc.
Entering ^A for example in the string data file shows length 1. When I try the escape character ^[ RS Logix 500 enters a backslash automatically (shows string length of 2) showing \^[
any ideas?
Thanks Doug
Solution Found
Found the answer, posted a while back. Surprised I didn't find this on my search earlier:
I don't know about MicroLogix, but in CompactLogix you can enter non-printable characters bij entering a dollarsign followed by a two-digit hexadecimal number, eg. $0A for linefeed, $0D for newline and $1B for escape.
If you're using an SLC, you can do the same by entering a backslash followed by the hex code: \0A, \0D and \1B.
Using the \hex has worked for everything and using the carat works for most characters.
Thanks again.
Justin
Hi all, My requirement is to send out escape character ( and also enter , line feed characters)from MicroLogix serial port configured in ASCII...
7,538
Hi, We couldn’t find anything specific, so am starting a new thread. I’m trying to migrate a config from a ML1400 to a micro820 & am experiencing...
103
I have an L24ER-QB1B with a 1769-ASCII card in slot number 4. I'm looking to send data to this zebra printer after every completed sequence. I'm a...
452
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
732
I am trying to import addresses and symbols from a PanelBuilder32 application into the RSLogix 5 Address/Symbol database - however each time I...
543
