ASi bus troubleshooting assistance
robcontec
Feb 2007
Bloomfield Hills, Michigan
25
I have a rotating machine with various ASi bus nodes inside the roating cylinder.
The processor is a SCL 5/04 the bus master is a SST dual channel card. using both channels, 31 nodes on the first maybe 31 on the second.
System has been running for 7 years.
Original problem
Channel one card LEDs fault flashing red comm flashing green.
Channel 2 comm led on solid
Was able to connect via the hyper terminal.
channel 1 originally displayed all 31 nodes but no info, tech support said this is possible
channel 2 displayed all info correctly (Inputs size output size.
After discussions with tech support, we concluded that the master was bad.
Had a new card drop shipped.
Day 2 installed new card, read the list, saved to eprom all is good, start the machine runs for 15 min.
Channel 1 agains shows loss of node info.
Talking with both IMF and the machine Mfg, decide to swapp channel 1 and 2 ( I used the original card for this test)
both channels now show loss of node info (comm flash green fault flash red).
channel one has damaged the card.
Can not read any info now via the hyperterm
I am trying to get a hand held programmin unit in (local distrib gone yesterday).
The Asi bus passes down the center column of the rotating drum through a coupler (to allow the drum to spin and the cables not to)
any suggestions at this time would be greatly appreciated
Tom
I have received some used Asi-bus material. All the material was used in a plant and in good working condition. At his moment I'm just testing...
3,235
I have a small project coming up (20 or so pneumatic valves with feedback) the customer has expressed interest in Asi bus. After searching the...
4,967
Has anyone any experience with these controllers (beleive they are IFM products but rebranded. Previously, no issues but since rescheduling a...
2,053
My firm has been asked to design an ASI Bus network. I have never worked with this before and wonder if anyone has stumbled across some...
6,295
Anyone know of a converter / gateway from Ethernet/Foundation Field Bus (FFB) to ASI bus as I have to use a 1756 ControlLogix cpu and no descrete...
4,503
