ASi-Interface With Siemens S5
LaRocca
Jul 2003
41
Hello.
This is the configuration:
I have a PLC S5-115U with a IM308C conecting with a DP/AS-Interface Link 20E.
This is my situation:
And I don´t have the Addressing and Diagnosis Instrument for AS-Interface Modules, also I know that is possible to make the addressing whith a PLC S7 A special function block (FC ASI_3422) is available for the AS-i commands in a SIMATIC S7 DP master. :(
This is my question:
How is AS-i slaves to be addressed with the PLC S5?? it have something like S7 special function block (FC ASI_3422)??, How I do in these case?
With this Help I can call, the AS-i address of an AS-i slave can be modified.
I think, This call is mainly used to add a new AS-i slave with the default address “0” to the AS-Interface. In this case, the address is changed from “AS-i slave address old”=0 to AS-i slave address new”.
Thanks ;)
Please, I need an example in ladder for use a ASi master with SIEMENS s7-200 CPU. Thank´s
4,524
Hi, Im not able to configure the Bihl-Widemann ASi master on the Control Logix Remote Chassis.It always results in faulty.Is there any specific...
2,408
Hi all, I have a question regarding ASI: We have a S7-313C PLC with a 343-2 ASI master. I use the following code to read te ASI I/O: L PID 256...
4,581
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
120
