Assign IP address
sweety616
Jul 2005
New Jersey
36
I built 4 panels using panelbuilder. Now I need to assign IP addresses to the panels and connect them to the DH485 network.What do I need to do? How do I make sure that my programs I built are working fine?
If you can download, then you are half-way there. (for known errors)
For the Addressing, just use 1-31 (providing that there are no other addresses that are the same). Keep 0 open for a PC.
You specifiy the address in Configuration options in the PV appliation or on the PV hardware itself.
Connect..interconnect, and wa-la.
The question as asked has me slightly confused, if you want to set the DH485 address open the application then click on terminal setup then Comms and set the Node address.
IP is Internet Protcol which is used for Ethernet.
I am sorry, I need to set the panelview on ehternet network and I need to assign IP address. How do I know which IP address is next available on the network and how do I assign it to a panel?
If this is an existing network you would need to ask the customer, most likely the engineer/maintenance person in charge of that network. If it is one you are setting up then anything that does not conflict and you may want to ask the customer if he wants routable or non-routable addressing (if this makes no sense then you may want to read about IP-addressing before making decisions). Another question would be if the network should be class b or c (this affects the sub-net mask and the total number of clients that the network segment can support).
Darren
Here is a 3-Com paper on IP-Addressing http://www.3com.com/other/pdfs/infra/corpinfo/en_US/501302.pdf
Here is a link about non-routable addresses http://www.easydesksoftware.com/news/news28.htm
Yet another link http://support.easystreet.com/easydsl/general-info/iptutorial.html
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,043
Hello Experts, I am a newbie in setting up the Allen Bradley PowerFlex drives and need to assign an IP Address to a PowerFlex 523 series drive...
4,831
Hello, I'm working on project where I'm using an S7-1200 PLC, and I'm working with 3 devices that I'm connecting on a Profinet network. I...
2,268
Hello all, I am doing a project where I need to use a 1769-L36ERM. I am developing offline as I am waiting for my hardware to arrive. I have a...
21
11,463
Hi Guys, First time using Rockwell CompactLogix PLC, I have no idea how to assign IP address to it. Now PLC is powered up, only 1 "OK" light is...
12,296
