ATS-S5 on VMware not working on P8700 PC
PhilS7
Feb 2010
Northants
For ages I've used ATS-S5 on a VM with no problems.
My PC has just gone to PC heaven and I've got a new Fujitsu Esprimo with a P8700. ATS-S5 runs ok, you can look at code etc. But I cannot download anything!
I've put the same VM onto an old machine and it's fine.
Tried three versions of VMware on the new PC and failed. An XP virtual machine will download an Interbus config (uses serial port) with no problems.
The parallel port must be working as the dongle shows up in ATS title screen.
Any ideas so I can work with just one PC???
Using XP as host OS by the way...
Cheers,
Phil.
What versions or release of VMWare? You might want to see if your removable device is enabled and porting from your host to your guest. Check device manager
VM Workstation 7 is the best I've used so far. I just got a new Dell E6500 with the SSD, T9900 and Win7 x64 and have guest VM on XP and I can use RSLogix 500, WinCC flex, Step7, etc. Downloading is no problem.
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Title says most of it. I have a module mismatch error in a Logix PLC (v30.11). The setup is for a standard I/O module, but the installed card is a...
866
I have been tasked with adding a remote display on top of cabinet to display current speed/RPMs of machine.(using 4-20ma control). Is there a way...
18
4,203
so after a previous thread about the panelview 1200. I figured everything out that I needed to get working with it. I've got the RIO discrete...
1,580
Good Morning, I am building a panel that has 120VAC, 24VDC, 12VDC, and 5VDC, and was wondering if anyone had any ideas for wire colors. I have...
3,111
